Dougie's Falklands Project
Started by Dougie, 21 July 2012, 04:49:17 PM
kustenjaeger
Greetings
I tend to do air support in a smaller scale than on the table so 1/300 for 10mm.  If I get round to the Falklands then it'll be easier as well with £1 Harriers and £0.80 Pucara from Heroics and Ros.
Regards
Edward
I'll keep using my Tumbling Dice stuff then!
Dougie
08 June 2013, 08:24:03 AM #92 Last Edit: 08 June 2013, 08:51:09 AM by Dougie
Work started on my Argentine AML90s  :) I have a set method for 20mm vehicles which I've altered slightly for 10mm. The photo below shows where I'm at. The vehicles cleaned up, primed and the cammo applied and then modulated. the vehicle on the left has had a filter applied. This is quite a subtle technique, the photo doesn't really show it but basically it unifies and gives depth to the colour. Might be a bit anal in this scale but I like it  :P I'll illustrate the next stages with some close ups! Dougie
Check out my blog: http://dougieswargamingblog.blogspot.co.uk/
Yup !!
Great stuff Dougie !! :-bd
Do you spray the camo or is it brushed on?
Dougie
Quote from: Hertsblue on 08 June 2013, 09:07:45 AM
Well a bit of a tale, aitbrushed the base on and was going to use my normal technique with whitestuff masking then spray the next colour. This vehicle was a wee bit small so the tan is just brushed on  :)
Very nice Dougie, very nice  8)
Quote from: Dougie on 08 June 2013, 10:34:58 AM
And very nice too.  8)
Dougie
A couple of close ups. Dougie
mart678
Very nice work Dougie they look great
They certainly do !!
Dougie
