1870 Prussian Infantry
Started by Chad, 05 November 2011, 01:59:02 PM
Chad
Any figures suitable for the above wearing the peaked feldmutze?  Chad
Chad
Forgot to say figures in greatcoats. Chad
WWI British infantry in greatcoat and cap?
Chad
OK. Anyone have a photograph?
Chad
Think I've just discovered Russian WWI and RCW in greatcoat and cap - excellent!
Chad
Nil thanks. I was hoping that they would have the fronts turned back rather than fully closed. Any other suggestions? Chad
The only ones I know of with turned back greatcoats are WW1 French but the kepi would have modified somehow to look like a feldmutze:-
What are you actually trying to model?
Chad
DP
Baden infantry 1866. I can use Bavarians minus the overcoat,but thought there might be a figure in greatcoat which is apparently their campaign dress.
Chad
Tough one that. Can't think of a suitable figure other than either trim and greenstuff or head swap. Bit tricky in 10mm. Sorry can't be of any further help.
DP
Chad
DP
No problem. Thanks for your consideration. I will go without the greatcoat.
Chad
