early WW2 French
Started by Jagger, 31 March 2010, 12:37:06 PM
Jagger
IIRC, the uniform and much of the equipment of early WW2 French army, fighting the German blitzkreig, were basically the same as WW1 French uniform and equipment.   So could you use Prendraken French WW1 infantry to build an early WW2 French force with decent accuracy?
You can use the basic infantry/Hotchkiss, and we'll be getting some masters from Snafu at Triples for some early WW2 French.
Jagger
Doug
I also have used the WW1 French as WW2 French they come up Ok, I have also used the WW1 French as WW2 Belgium troops using the WW1 British command as Officers. For artillery I have used French WW1 75's with limbers from the WW2 German range.
ronan
Hello
Thanks for sharing these informations.
I'd like to see some French Dragons portés, they were different from french infantry..
I think this is one :  http://militaria.histoireetcollections.com/images/produits/numero_326_1097057507.jpg
And I will do some Corps Francs, mixing SCW and French..
