A "new" approach to depicting built up areas on the table
Started by pierre the shy, 10 May 2024, 11:48:43 PM
Quote from: FierceKitty on 13 May 2024, 09:06:13 AMEat your heart out - I was at Austerlitz for the anniversary reenactment.
That must have been quite an experience Kitty.
Nearest experience I had like that was visiting Waterloo in 2015, about 3 days after the reinactment finished. There was about 3 campervans left in the carpark. I was asked to get some stuff from the shop there but I all I could find was a reproduction poster of Napoleon crossing the Alps and a small silver bust of the man himself as the shop had been pretty well been picked clean.
As regards to Baccus TTT guess its a matter of choice - if you like them great, if not look for another method.
It was jolly cold - I'd never taken the description "frozen like iron" seriously before, but the field was like that. The way it transmitted the vibrations of gunfire was terrifying, even knowing they weren't actually trying to kill us.
Other notes: hot mead in a Moravian midwinter is a most agreeable drink, and going to a spectacle with another man and a woman you both fancy can be quite...interesting, shall I say?
Just to state a position. I use 6mm structures with 10mm figures, 10mm structures with 25/28mm, and 1830mm structures in real life. In the first two, if a structure is in the way, I move it aside. In the latter, I glare at it and walk around or through.
Quote from: Last Hussar on 12 May 2024, 08:44:48 AMIthoriel, part of the problem is that you don't realise how big things are, until you see them scale.
"Small or far away?"
(sorry - it just had to be done - a bit like the Wendy houses thing ... I'll get my coat!)
Quote"Small or far away?"
I have been resisting the temptation ... thank you for taking the bullet in my stead :D :D :D
Quote from: Last Hussar on 12 May 2024, 08:44:48 AMpart of the problem is that you don't realise how big things are, until you see them scale.
I tried that excuse with an ex girlfriend and she just laughed. :(
QuoteI tried that excuse with an ex girlfriend and she just laughed. :(
;D  ;D  =O
