Has Pendraken ever considered offering dollies?
Started by Corso, 07 January 2024, 02:38:26 PM
Corso
Just wondered if you've ever considered offering dollies to the community?
Not saying I'd even be that successful but I've enjoyed a bit of greenstuff sculpting and think it could be an interesting 2024 project
I think you have posed an interesting question Corso and one deserving a serious answer. My guess is no since they are likely considered an IP worth guarding. Likely Leon will reply at some point.
Corso
Quote from: Orcs on 07 January 2024, 04:16:30 PMWas it a Barbie or a Ken you were after?  :)
I found your answer funny, Orcs. Didn't mean to sound like a (fill in the blank)
 :D
How large and thick would a 10mm dolly be, would be my question.
Working from a wire armature would allow the sculpting material to be built up and give strength to the miniature but, converting a 10mm dolly would, possibly, see the miniature resembling an overweight person - at least, that's my initial thoughts.
I don't know how the sculptors work, dollies or armatures?
I have had some 28mm dollies to play around with, when I worked for Stuart at Col. Bills, and they're obviously thinner in overall thickness than what a finished miniature is (allowing for layering of sculpting material). That's why I'm wondering what size a 10mm dolly would be, and could it be successfully cast to order without a lot of wastage (not that I know much about casting or casters).
Rimmer: "Aliens."
We do have a variety of dollies but I'm not sure if they're something we'd want to sell to folks.  It might be something we could get a sculptor to knock up and then we could sell them as a pack.  Just basic poses, so standing, walking, kneeling, crawling?
Quote from: d_Guy on 07 January 2024, 09:13:36 PMI found your answer funny, Orcs. Didn't mean to sound like a (fill in the blank)
 :D
No worries, you were right, he deserved a serious answer.
Quote from: Orcs on 07 January 2024, 11:09:01 PMNo worries, you were right, he deserved a serious answer.
But he asked it here...
Techno 3
Personal thoughts...
The main problem I foresee, is that the dollies I've made, and use, are not just ultra thin wire frames.
The very originals that I produced for Leon were too 'thin' to cast well....So I basically chunked them out so that they would cast successfully.
These are the ones I use nowadays, BUT.....in every case I use the Dremmel to grind  these down all over, a tad, before I start adding the putty. Though I tend to leave the faces alone.
Hope that helps.
I'll do this later
Matt J
Are you saying my Roman Triari has the same face as my US artilleryman  :o
The eternal soldier  :)
Beep
Quote from: Matt J on 08 January 2024, 10:39:45 AMAre you saying my Roman Triari has the same face as my US artilleryman  :o
Only if they both have a big nose!
Techno 3
QuoteAre you saying my Roman Triari has the same face as my US artilleryman  :o
If they're both wee men that I've made.....and it's the same basic pose, quite possibly.😉
I'm not sure how many different dollies I've got on 'Phil's' dollies mould....20?..30?....and I have  'revamped ' them three or four times....so the faces are reasonably varied.
I'll do this later
Thanks, Phil, for another glimpse behind the curtain, be careful with that Dremmel X_X
I find the process of creating and producing figures fascinating :-B
And as usual the more I learn about it the more there is to learn :)
