28mm Italian Wars- Mounted Arquebusiers
Started by Atheling, 17 October 2022, 07:57:32 AM
Atheling
After a period of absence away from the painting table due to illness, I'm very happy to say that I'm back with a bit of a vengeance; three projects on the go again so my Early Byzantines are getting a few command stands added, another unit of Anglo Danes is very near completion and half of what will be a 12 base unit of Italian Mounted Arquebusiers are now complete and here for display :)
I made the school boy error of forgetting to superglue the magnetic sheet I use on then bottom of my bases and relied just on the viscosity of the adhesive to stop any potential warpage of the bases- but hey, I''ve been out of action for a while so I'm forgiving myself for that slight infraction.
As usual, more pictures and waffle can be found on my Just Add Water Blog here:
https://justaddwater-bedford.blogspot.com/2022/10/italian-mounted-arquabusiers.html
Here you go- Hope you like the work :)
In Line:
In Column:
Single base pictures to come when I get the time. That or the rest of the unit, whatever comes first :)
Atheling
As promised, here are the close ups of the single bases. Apologies for the condition of the background, I'll print out a new one ASAP!
More up close and personal pictures can be found on my Just Add Water Blog here:
https://justaddwater-bedford.blogspot.com/2022/10/italian-mounted-arquebusiers-single.html
Lovely figures and superbly painted.  What make are they?
Vincenzo21
