Country File
Started by Heedless Horseman, 13 June 2021, 01:04:19 PM
Gwydion
The barn is obviously an awkward place for a wasps nest and has to go, but if you can you should live with wasps as far as possible. B****y annoying little b*****s but they do kill an enormous number of insect pests and spiders so embrace the wasp - just not literally!  :D
Quote from: Techno 3 on 05 July 2023, 06:26:37 AMI reckon the mites had such a good time as the chickens had been locked down for so many times, and for so long...and hadn't been able to have a dust bath.
We'll get something sorted out for their run, if they have to be locked in, again. (Should have thought of this before !)
The 'Worsps'.....A bee-keeping friend of a friend is coming around in the next couple of days to sort those out. :D .I wasn't going to take on the half football sized nest....(My guesstimate would be there are a good few dozen, if not 100 + in that one....The one in the bird box can't have THAT many in it (not enough room ?)......Probably could have used the electric 'fly swat' on those.
Flockdown is a *pain*.
I find a bit of small sand and a load of diamateceous earth into a small dip is a great incentive for the chickens to have a good roll around and dust bath!
Techno 3
Worsps gone. :)
(I expected to see a lot more peed off worsps, flying around, while matey was working on the nests...Those that weren't in the nests, will die off in the next few days. (Apparently)
I'll do this later
Heedless Horseman
I HATE Wasps... don't mind Bees. Thing about either is to wear protective kit that they can' get into. Most important thing is not to 'Flap' around... it excites them ! Poison will be carried into nest and will 'do' for most.
Techno 3
I did take my 'Executioner' (?) into the barn, while Matey was dealing with the nests.
Haven't zapped anything with that for a long while...I was surprised the battery hadn't given up the ghost.
I thought the advantage in using that, would be that I wouldn't have to swish it around.
I'll do this later
I semi-literally flamethrowered a centipede in the shower this morning. Insecticide won't kill them, but hold a flame in front of the spray...
Quote from: FierceKitty on 08 July 2023, 08:36:32 AMI semi-literally flamethrowered a centipede...
'semi-literally flamethrowered'.  That's an interesting concept.  I presume it was unnecessary to fully-literally flamethrower it? :D
Quote from: FierceKitty on 08 July 2023, 08:36:32 AMI semi-literally flamethrowered a centipede in the shower this morning. Insecticide won't kill them, but hold a flame in front of the spray...
That seems somewhat excessive, do I gather your local centipedes are... somewhat less friendly than UK based ones :D
Heedless Horseman
Dunno what is wrong with a Centipede... or Millipede... maybe regional. When an evil teen, used to flamethrower greenfly with lighter. Don't do it now. Food for something!
Quote from: Heedless Horseman on 08 July 2023, 02:14:12 PMDunno what is wrong with a Centipede... or Millipede... maybe regional. When an evil teen, used to flamethrower greenfly with lighter. Don't do it now. Food for something!
Also with a venomous "bite" much to be dreaded. I have cats to protect, and even a human make be taken unawares.
Quote from: John Cook on 08 July 2023, 01:46:03 PM'semi-literally flamethrowered'.  That's an interesting concept.  I presume it was unnecessary to fully-literally flamethrower it? :D
"Throw" suggests a longer-ranged projection. This was a close-combat weapon, selected since the dam' creatures are harder to put down than zombies.
Techno 3
Asian centipedes are a LOT bigger* than the ones we get in the UK.... with a really painful bite  :o .....IIRC.
*Sodding enormous springs to mind.
I'll do this later
IIRC, in the original book version of the James Bond "Dr No", it is not a spider dropped on Bond, but a millipede.
QuoteIIRC, in the original book version of the James Bond "Dr No", it is not a spider dropped on Bond, but a millipede.
Still a creepy crawly.....
Yeah, that's sounding like a flamethrowering is well in order!
