Repairs on an ancient set of Heresy fantasy figures for Blood Bowl, and building EE terrain for Legion Imperialis.
There's only so much if the latter I can do, I'm off to walk the dog!!
Buildings painted, photos later, just so teh post count goes up a bit...
A lot of progress on a lot of figures, some wait final varnish (but it's wetter than an otters pocket at the moment), others are done and await photography, while others just need final finagling and basing.
Baes painted on 6mm camp.
Half 6mm Plains War Cavalry painting finished. Need to get the other half done and based by Friday night. Then they can be passed on to a friend.
27 x 28mm Napoleonic figures almost finished today. Just need varnish and basing.
Found a missing pioneer, and painted him today. Thus 28 x 28mms varnished.  8)
Finished basing Gaz, Nav, Id and mates.  ;D
Hedgehog witch hunter and shrew shamen (called Ezza Goode) done apart from basing.
Coats, trousers and flesh done on two different scales of Napoleon French infantry.
Just finished two new SYW infantry units to use up some leftovers, plus small reinforcements to my Assyrians and 17th-century Scotchmen.
Two scales of French Napoleonics now just need cords and flounders, coat/blankets and straps doing.
QuoteTwo scales of French Napoleonics now just need cords and flounders, coat/blankets and straps doing.
Scales and flounders? sounds very fishy   :)
Yes I've already got me coat on, its freezing here today.
After a long break, I finally found time and the inclination to start painting some terrain, which felt good :) .
Glad that you have got your painting mojo back Steve.
If you find a bit more, can you send it my way!
If I do, I will Fred, but don't hold your breath ;) !
New job is really cutting into my Painting time, but a friend gifted me his 10mm Imperial Guard division at the weekend, and seeing as I'm using it in two weeks, rebasing has started!
