Hard time picking a scale
Started by acctingman, 26 August 2016, 06:29:52 PM
acctingman
So, I'm going to be giving Chain of Command a go. I'm building a 4x8 table set in the post D-Day country side, but I'm having a hard time deciding what scale I want to use. Originally, I thought 6mm, but after buying a pack of M4's and painting them up there was just no way that would work for me. Just too small.
I thought about buying a Zzezda 1/100 kit and putting it on my table to see how it looks.
Can anyone here post some pics of their similar sized tables with either 10mm or 15mm or send me some links? Be nice to visualize before I plunk down $$
I'll take a look at some photos here on the site too.
4 x 8 is massive by the standards of many gamers - especially for the sort of things you have discussed doing, With a table that size, I think you could just pick any scale, just pick the one that you think looks the nicest. There isn't a 'right anser' to your question.
For Chain of Command I've gone with 15mm scale. Mainly Peter Pig but I have some Zvezda kits too.
For me it was a good balance of detail, affordability and space requirements.
I play on an 1800mm x 1200mm table (roughly 6' x 4') which has been plenty of space.
I tried 10mm initially as I use them for BKC (which I play much more often) but my fat, fumbling old fingers found the individual 10mm figures a trifle hard to handle.
Here's a 6'x4' with 10mm figures (SYW) and terrain:
acctingman
26 August 2016, 07:50:53 PM #4 Last Edit: 26 August 2016, 07:53:53 PM by acctingman
Since I'm doing skirmish then 15mm might be the best route.
I've seen a few images of 15mm on a similar size table as mine and it looks good.
I'll paint up a 1/100 kit and try and pick up a cheap 1/144th scale somewhere and put them on the table.
Thanks for the picture Leman
lentulus
A 6x4 table here, and some images in other posts arranged on 8.5x11 sheets of paper and the like that might help your planning..
http://10mmpatrioticwar.blogspot.ca/2011/10/game.html
Subedai
Mt table is about 5' by 3' 3" (1.50 x 1.00m and this is an example of my WWII layout. Would work with 10mm up to a point.
MickS
Blog is at
For some forces on a 3' by 6' , check this battle report by me. No skirmish though!
http://www.pendrakenforum.co.uk/index.php/topic,8283.0.html
PS: nice layout S!!!
acctingman
Quote from: petercooman on 26 August 2016, 08:31:26 PM
Thanks Peter
This shows me, at least to my eyes, that a 4x8 table is more than enough for 15mm platoon+ each side
Quote from: acctingman on 26 August 2016, 09:26:31 PM
Thanks Peter
Yes, a 4 X 8 is definately big enough for that. You'll have lots of maneouvering space on that!
My flames of war armies fight on 6' X 4' tables, company strength.
You will need a lot of terrain.
Ok, here's a close up of some WWI 15mm PP Belgians, which I use in company level games. This includes 15mm scenic items:
acctingman
Quote from: Leman on 26 August 2016, 11:23:05 PM
Nice looking stuff there Leman, Thanks!
NTM
27 August 2016, 07:33:29 AM #14 Last Edit: 27 August 2016, 07:47:50 AM by NTM
Do you already have a lot of terrain and scenic in one scale or another? If so I would suggest selecting one of those as it is a considerable investment in time as well as money to get that from scratch especially considering that CoC can be very terrain heavy. You'll need a boatload for a 8x4 table.
