Neil's 10mm adventure
Started by NeilCFord, 15 October 2015, 12:42:39 PM
Filler paste with some acrylic colour added, this fills the base and levels out the individual base of each figure.
I then dirty wash that (ink) and drybrush a highlight (OR PVA it all and add sand and then dirty wash when dry and dry brush) - whichever you choose, the final touch is flock added sparingly, mainly at points where the figure base might still be showing and in any area that you think will help to naturalise the base.
For 10mm I favour the very fine turfs (like super ground down flock) from Woodland scenics with a tad of whatever you fancy added in.
here are a few bases that use these .... http://commanders.simdif.com/video-links.html (sorry I can't seem to get the URL for individual photo's since I have upgraded to my latest OS).
Click on any photo to get a close up of the basing - not saying it is the best, but I think it passes muster for wargame standard.
- should be a decent picture of some of my basing on Pendraken Ottomans - simple sand on PVA with a bit of static grass and some Javis ballast for contrast.
These days I like a "three part" basing, usually sand and static grass or flock, then rock/shale or clump foliage for contrast depending on terrain type and scale.
Very nice, indeed, Pixie !  8)
I think you said that last time I posted them :D
Must finish the rest of the army...
NeilCFord
Thanks all. Going to give it all some thought. Expect to go with something simple though.
- Neil.
Very nice indeed
NeilCFord
Latest Developments
So a little progress has been made:
BUF Militia test basing using sand (Javis Desert Sand and Stone Mix - JS 75)
Just waiting for it to dry, so I can PVA and try out the new Dark Meadow Green heavy scatter mix.
Alongside that have base coated six sticks of The Bishop of Salisbury's Militia in VMC Khaki Grey. Trying John Cook's technique that he outlined at http://www.pendrakenforum.co.uk/index.php/topic,12847.msg179792.html#msg179792
Assuming the basing technique works out, then these will get based up the same way once they are finished.
- Neil.
Those are looking really good, Neil.
NeilCFord
Thanks all! More pictures later. Quite pleased how the new basing has turned out.
- Neil.
NeilCFord
Finished up the basing. Did a second squad just to see if I could repeat the process.
Before applying the PVA and scatter, I used Coat d'arms Light Brown Super Wash to make the sand darker. Gives it a more muddy quality. Which seems more appropriate for troops destined to be fighting over the Wiltshire Country side.
- Neil.
Like the Fascist one - the mix is a better contrast when there's a bit less of it!
NeilCFord
Possibly a bit too much PVA on the second base. Learning as I go along. "Less is more".
- Neil.
The left hand base with less scatter on it is definitely better.
