7mm dice frames
Started by Nosher, 28 February 2015, 01:20:00 PM
Given im a complete feck-nugget and misplaced my bag of 7mm dice frames does anyone have any kicking around that could answer a question for me?
What are the outside dimensions across the flats? Im guessing 11mm (7+2+2) which if im right might scupper plans i have for them....
I thought, I've got some of those on my desk, right in front of me.
But they are clearly in a pact with yours and have hidden too.  >:(
After several minutes of poking around, I have found a loose one - they are only about 9mm square - the sides are very thin.
Ta muchly. Looks like my DIY ;) basing project for Blucher might be back on
Yep, 9mm across them.  The frame itself is only 1mm, but it's surprisingly robust and we don't get many broken ones.  We can always do them thicker as a custom job if folks want it.
gregernest
All your new bases and frames are in 2mm MDF, right?
Quote from: gregernest on 02 March 2015, 08:12:59 PM
Yep, always 2mm thickness.  We do keep 3mm in stock in case anyone wants it though.
