He's on about bl**dy Mongols again.
Started by Subedai, 26 June 2014, 10:02:20 PM
Subedai
What are the chances of armoured Mongols on armoured horses being added to the existing range at any time? They are the only troop type missing and there were quite a lot of them.
Blog is at
Can't you use some Centurions?
I'll get me coat...
Matt J
+1
(if not i'll have to crack open the green stuff)
Beep
Subedai
Quote from: Matt of Munslow on 26 June 2014, 11:18:13 PM
+1
So that's where I've been going wrong. I thought you were supposed to use it before it got hard enough to crack. (Keep it clean fellas.)
Blog is at
QuoteI thought you were supposed to use it before it got hard enough to crack
Quote
With a set up line like that - You are joking!
I'm not sure where we'll be able to fit those into the schedule, so I've popped them on the request lists.
Subedai
Quote from: Leon on 27 June 2014, 03:28:44 AM
K Ta.
Blog is at
Dave Fielder
Sandinista
Quote from: Subedai on 26 June 2014, 11:33:35 PM
Can't 'crack' green stuff....Got too much 'give' in it  ;)
Brown putty..That you can shatter and crack !.....Quite brittle when it sets.)
(Hardly ever use the stuff......Too bloody expensive !)
Cheers - Phil  ;)
Add my vote - also with sheilds....
Rimmer: "Aliens."
Subedai
Quote from: ianrs54 on 19 January 2015, 09:50:35 AM
The only definitive evidence of Mongols using shields I have found is when the Guard (the keshig) were on guard duty on foot. None of my sources mention using them mounted or in combat.
Blog is at
cbr3d.com
Being new to the forum but having read the thread about the 'top 10 wishlist' I would also like to add my vote to the list as well.
