Pics of our trees!
Started by Leon, 09 May 2011, 07:13:44 PM
Just took a few shots of the show displays I've done for these, with some handy little Romans on them for an idea of size.  (I was going to put a coin next to them and then comlpetely forgot...  :-[  There's only moths in my wallet anyway!  :D)
These are all on the website here: http://www.pendraken.co.uk/Resin-Scenics-and-Trees-c25/, and are £2.50 per pack.  Numbers per pack are in brackets.
TRD35 (10) and TRD48 (10):
TRD50 (10) and TRD60 (5):
TRD90 (4) and TRD115 (3):
TRC85 (4) and TRC118 (3):
TRP30 (10) and TRP40 (10) (and yes I know they've got Romans on them, it's all I had to hand!):
TRP50 (10) and TRP70 (10):
Squirrel
Thanks for the photos Leon, those are really rather good! More to add to the never ending wish list :'(
Kev
"Join the Legions, see the world they said, didn't say we'd have to walk through every patch of trees on the way there!" moaned Cassiun Longinus.
"Shut it private, or you'll be back to garrision duty at Mediobogdum!" his Centurion barked!
"Oh not Hardknott pass AGAIN!"
They look good. Nice and big. Which is good as model trees are often rather small, but real trees are big.
Maenoferren
ooooooooohhhhhhh  :D
prepare for an order for the palm trees ;D
I think I may have to get some more stock in!
Nice to see real sized trees, how well do they balance ?
Quote from: Leon on 09 May 2011, 07:13:44 PM
Those pesky Romans get everywhere.
Quote from: ianrs54 on 10 May 2011, 08:52:19 AM
I drilled holes through one sheet of 2mm MDF for the smaller ones, and then a bit of superglue, and they've not moved at all.  The bigger ones had holes drilled in two sheets (4mm) and the same.
Maenoferren
what are the palm trees made of and how are they fixed?
Quote from: Maenoferren on 10 May 2011, 03:17:40 PM
They're all plastic trunks, with plastic layers of leaves which slide down over a slight barb at the tip of the tree.
Do we have an indication of price? Anything will be better than the £10 Skale Scenics charge for three. :)
capthugeca
Quote from: Hertsblue on 10 May 2011, 06:16:40 PM
Prices are here: http://pendraken.co.uk/Resin-Scenics-and-Trees-c25/
And yes a lot cheaper than Skale.
These are all on the website, and are £2.50 per pack.  Numbers per pack are in brackets.
:D ;) 8)
Anyone tried alder cones for the mass of closely forested trees? I have found that drybrushing with various greens and browns looks pretty good after they've been glued together and based. And the cones themselves are FREE.
DP
Not sure i'd know an alder if it sat up and bit me. :-[
